I'm trying to calculate the magnectic flux of an induction motor,. However, the mesh grid automaticly generated has about 40.000 points whist the student version only allows 25.000. Is there anything I can do to reduce the mesh size, even if this means loosing accuracy?
To reduce the number of nodes on your project you can edit the mesh and change the option. To do it:
When you open your Flux project >> in the top select mesh
Select aided mesh >> edit
You can change the mesh data
The second option deactivate the aided mesh and create your own mesh (for example mesh point discretization, line discretization).
Best regards.
