Does Time Stamped Signal can be used as import variables as input in HyperStudy to define Genetic Algorithm
Hi @Jigar,
We require more details on the use-case to suggest accordingly.
One can use any of the optimization methods in HyperStudy & the process will not be different for GA optimization method. The process of adding/importing DV's in HyperStudy is a common step in HyperStudy for any evaluation (DOE/Optimization etc.)
Since, it would be a support request, kindly mail us on hwsupport@altair.com so that the support team can provide the required support.
Many thanks.
Kind Regards
Garima Singh
