I'm trying to access the elements of a realization from a script in Python. I'm using Hypermesh 2025. The realization is of a fastener (type Hole) with a head made of CBUSH and a body made of CBAR. The body is extended with two more CBAR elements (number of body extensions 1, Body Ext Config:CBAR).
In the GUI all goes well. I then want to modify and organize the created elements. To retrieve them I'm using a simple function:
import hm
import hm.entities as ent
def retrive_bolts():
model = hm.Model()
bolts = []
# Select all connectors in the model.
all_connectors = hm.Collection(model, ent.Connector)
# Seach for those representing bolts and realized
status, result = model.hm_ce_datalist(all_connectors)
for connector in result:
connector_object = connector['id']
if connector['config'] == 'Hole' and connector['state'] == 'realized' and connector_object.ce_style == 'bolt':
bolts.append(connector_object)
return bolts
So far so good, I have a list of objects where each one is a connector of the type I want.
After searching, the only way that I found for retrieving the elements than have been realized for a certain connector is to do bolts[0].realization_weld_elems
That is where the weirdness starts. For some reason, the firs connector that gets realized is missing one of the beam elements. The rest is fine. It can be check with something as simple as len(bolts[0].realization_weld_elems). All realizations but the first one have the correct number of elements. In particular, the first one is missing one of the beams that extend the body.
I don't know where the error is coming from but it looks like a bug.
Anyone can help me with a workaround? If I can retrieve the elements some other way in a connector by connector fashion I'll be in the correct position.
thanks
