Is Hypermesh handles Graphene matrial modeling ? Any example model available ?
Hypermesh is a preprocessor for setting up fea analysis for various solvers. You should be able to look into the solver help you are using to check their material models. Than you can see if Hypermesh supports it. But first you need to check it is supported in the solver.
The solver I am using is RADIOSS
