Circuit Configuration of PMSG and SynRG
User: "Amina"
Altair Community Member
Dear Support Team,
I want to simulate a PMSG and a SynRG separately in Flux. It is clear that the machine topology will be the same as in motor mode. My question concerns the circuit structure of these machines in generator mode. In this case, what should be the circuit configuration and connections for the PMSG and SynRG?
Is there any example in Flux for this case?
I appreciate your attention in advance.
1 - 1 of 11
    User: "Lavanya Vadamodala_20519"
    Accepted Answer
    Hi Amina,
    From Flux versions 2024.1, we have an example on Wound Files Synchronous generator under Flux 2D examples < Application notes. This consists of how to setup the circuit and run it as generator in On Load test.
    This will help you as reference.
    Thank you,
    Lavanya
