Dear,
I have measured gains of all my 16 single elements of my antenna array, where I'd like to use it as the pattern of a directional antenna in ProMan.
Here's my thought. My data is in a .csv file, which is not quite able to be converted in to an .ffe file (if there's a way please ignite me), but I managed to convert it into an .apa file. The .apa file can be opened in Aman, and where I'd like to use the Aman array tool to generate an .ffe file of a 4x4 array of such an element.
I'm so far mainly comfused by the axis setting of Aman.
Fig.1 Single element pattern
Fig.2 Aman array tool panel
In such a setting do I get an 4x4 array on XZ-plane? Cause there's a strange mirror effect of my results while using a default dipole results in no such thing.
Fig.3 My strange result of a 4x4 xz-plane setting
I can't understand why there's a main beam to both +-y direction… the pattern of the element seems to be nicely cut by the xz-plane? I also tried to reduce it to a linear array, while I found out that the element spacing can't be 0. I left it 0.5 lambda as default…
Fig.3 Strange requirement of element spacing while creating a linear array
Fig.4 4x1 result
Same happened and I'm not sure about whether it's my understanding of the axis caused the problem, or the formatting of an .apa file or anything?
If there's some other method to avoid all these and making it possible to use a .csv file in ProMan please comment!
Thank you very much!
Best regards,
Coco
