When I try to save my pre-simulation this problem appears.
Hi @JorgeRenzo12,
It looks like either the source file you are trying to save may have been moved from its original home. Is it possible that after you opened this model you moved the DEM file to another directory? Or is this the first time you are trying to save a model?
Alternatively, where you are trying to save this file to may not be reachable. This could be due to your write access, a directory path that is too long, or if the directory path contains special characters. Please ensure that you can write to the specified path and that the path is clean.
Hope this helps!
Adam Reid
