I am trying to make a model in HyperMesh 2023.1 where some SPCs come from enforced displacements. I have the data in a csv file with the format of the image below, which is the same as the one Altair Help provides in Fields (rot degrees of freedom are all zero).
However, when realizing the field as Displacement, the following message appears regardless of the interpolation method selected.
Am I missing something?
Thanks in advance.
Kind Regards,
Alfonso
Edit: I have just discovered that realizing the field as Temoeratures (with the same csv file) results in a load collector of TEMPs with the value of the X displacement.
