Hi all,
Is it possible to carry out a loaded tooth contact analysis (LTCA) of a crossed helical gear in Inspire?
My goal is to determine the cyclically changing and recurring transmission error (TE). Depending on the meshing situation, load  and material pairing, I have a different tooth deformation under load. This tooth deformation must be determined for each angular position of the drive gear. The tooth deformation results in a small angular deviation of the output gear from the theoretical angular position, which is ultimately my transmission error.
In the literature, there are calculation methods for spur-gear, helical-gear and bevel-gears, but not for crossed helical gears.
I would be grateful for any useful tips on how to proceed.
