Hi, Need clarification in the dispalcement measurements in random vibration. Which one to consider RMS disp or PSD displacement?
Units are in mm, PSD (g2/Hz) inputs.
I want to check the displacements in random vibration. But the displacement are starting from some random number not from zero (blue color contour), how to check the actual displacements in random vibration? Checked for magnitude and individual directional displacements, also tried derived results.
