"So, I am trying to generate a powder bed that replicates a powder with the following PSD: the particle sizes D₁₀, D₅₀, and D₉₀ are 24, 48, and 72 µm, respectively. In Altair EDEM, I used the following settings:
The particles are spherical, and I used D₅₀ for their radius.
For some reason, I am not getting the desired powder bed PSD. Am I using the wrong Mean and Standard Deviation settings? I used online equations and help from ChatGPT, but the results are still off.
Would any of you know the correct Mean and Standard Deviation values for the specified D₁₀, D₅₀, and D₉₀ values? Any tips would be greatly appreciated.
Thank you!
