Hi everyone,
I am attempting to create CBEAM elements (Nastran) to represent some tubes which have an oval shape. The way I am doing it is by line meshing a line with CBEAMs and then assigning a PBEAM property which reference a beam section collector which references a beam section which I defined using a sketch.
The problem is that when I create the sketch, Hypermesh realizes the sketch as 2 surfaces (the wall thickness surface and the inner diameter surface). I am only interested in having the wall thickness surface. How can I delete or de-select the inner surface?
Here you see the beam section definition. Note the Number of Parts showing as 2 (the 2 surfaces).
Here we can see the 2 surfaces created. The idea is to have just a oval loop.
Any idea?
Thanks and have a nice day.
