Please check the error i am getting. How do i resolve?
Hello @sandeep123, the error you see states that parameters in the connection must be equal. Are you using the same medium in both the components? Best regards, Orestes
Yes same medium only. Ethylene glycol
Hello @sandeep123, is this a custom medium that you've created or you are referring to the ones build in the component? Can you please share your model. I tested both glycol20 and glycol50 and run just fine. Thanks, Orestes
