Hi! How to collect the data of the fuel consumption of automatic motorcycle when simulated on different driving events?
Thank you!
Hi @sudo,
Assuming the drive cycle results are from MotionView, the fuel consumption of a vehicle can be approximated using the engine speed and engine torque. Most fuel consumption maps can be requested with respect to engine speed and engine torque, like so:
Therefore, the instantaneous fuel consumption rate could be approximated in simulation with this information.
Hope this helps!
Adam Reid
