Error creating new process when Analyzed
when i tried to run my casting simulation i get this message and i have checked my ram availability and other satisfactory requirements too. I have also not set my run directory to a shared drive or virtual one, but i have not yet done my reinstallations.
what would it be the problem
i have attached my file above.
So even now after i try to simulate it in inspire cast 2025, i doesnt give me error creating new process
but now i see a new message of error which shows
so what show i do now as this model that i have used now has been tested in both the versions of the inspire cast 24 and 25
24 says error creating new process
25 says meshing error
so please help me find answer for this issue as I'm unable to do anything with this simulation software. I hope to get good answers from the community. THANK YOU
Hello @venomousDNA ,
I have figured out the cause of mesh failure. It was related to the way runner system was connected to the part. I have fixed it and now it has started computing the simulation. I have also attached the fixed CAD here. Please use this and it will work fine.
Yes. if you look at your model closely, cast part and runner is connected by 3 small entinties. Not sure how you created them. As they are separate thin bodies, mesh creation was difficult as you are trying to create with large element size. I combined those bodies with runner using Boolean.
Hi @MilanRaval
Understood. I had issues with Un connectivity, so I used Boolean modifier to fix the three gating issues you mentioned, but even then, I'm getting mesh creation error. Also, now when I tried running your file, I'm getting error: Error creating new process and also the mesh error occasionally
I just tested that the model is working fine in Inspire Cast 25. If you are using older version, I suggest to use latest. Also, I noticed that the gravity direction in your setup is incorrect.
