I'm learning how to work in the subsystems browser to control model configurations and I have low familiarity with include files. My model has RBE3 elements in each configuration that connect to the same set of elements (same mounting holes across concepts). I did a drag-drop operation on the "part" entities associated with each of the configurations into their respective subsystems. The nodes associated with the mounting elements appear in only one of the subsystems and I received this error when conducting a solve:
To resolve, I drag-dropped the "Nodes" associated with the single subsystem into the main "Model" subsystem. The model solves without error now, but "ghost nodes" show up when I open the results in HyperView that are associated with an inactive subsystem part. I can hide the nodes manually in HV, but I'd rather find a way to exclude them from the results file. The image below shows two different "ghost node" sets that show up in my results (one has nodes highlighted, the other doesn't).
Is there a different method I can use to:
a) avoid inclusion of nodes in subsystems during drag/drop configuration construction
b) avoid "ghost node" generation
Thank you,
Mandy
