Hi all
I'm currently working on an university project where my aim is to bend a certain part of the structure 15 degrees in rotational X and 15 degrees in rotational Z angles. This deformed structure will then later be crashed against a rigid wall and the results compared to the crash of the non-deformed structure
From what I've found out, the /IMPDISP keyword is what I need, however I can't quite figure out how it works. The unit for Angular Displacement in Radioss is supposedly radians (rad) according to the Manual, but the deformation in the result doesn't correspond to what I expected. In fact, I can't quite figure out what to input for the precise rotation angle I need because I don't know how the command interprets the Curve data
It can also be a possibility that I am using an entirely wrong keyword for my goal. Maybe there's a command to precisely bend a structure by inputting the angle?
Any help is welcome 🙂
