Hello, so what happened to me today was very weird. I started making a very simple model to test force applied by a curve. The model is very simple and the checks were ok. But when I ran it, I got a random error in the .xml file. The simulation before that would appear to run normally. I am enclosing all files. Does anynone know what to do with that?
Hello @VKR , The issue seems to be with the template format that you have been using. You can refer to the below snapshot for comparison. It was a small typo, but was causing the issue.
