I am working on utilizing the radiated sound method of external acoustic sound pressure measurements in hypermesh, and want to use this response output in optimizations. The standard outputs for responses in optimization do not directly point to acoustic pressure, but since this is a frf response technically, would frf pressure be the correct response type to call? Or is there a different type I should be using?
I am also using a minmax objective on this optimization which requires a dsysid or objective reference. If my goal is to reduce the magnitudes of the sound pressure response, which type of input would be best as I have not created an optimization that requires these options for objective inputs?
Thanks for the help!
