I want to apply a 2 MPa load in the vertical direction to this model. Could you help me with how to set the load?
I want to set the contact condition to 'slide'.
Hi @julia4567,
Pressures can be applied using the Pressures Tool. Simply select the faces you want to apply the total magnitude to and the tool will create the necessary number of PLOAD4 entities:
Hope this helps!
Adam Reid
Thank you for your reply. I set it as above, but it doesn't work. Can you check if the conditions in my model are incorrect?
