I'm trying to set up a MAXMIN optimisation and I want to use DOBJREF. I tried to define two references in HM2023 to point to 2 different responses with the same DOBJREF and HM doesn't agree with me - it says New entity id conflicts with existing id.
I found this in the help file for DOBJREF: "
- The same
DOID can be used for multiple DOBJREF entries. If only one DOID is used, only one MINMAX=DOID entry is needed in the Subcase Information section."
I defined two DOBJREFs with the same id manually in the deck I'm running but they were not read properly by HM - they got scrambled.
Am I defining it wrong ? For reference I'm trying to do a MAXMIN with a mass and a frequency response.
Thanks,
Chris
