Need help in defining correct interface between two interacting components
User: "Saket_Agarwal"
Altair Community Member
Updated by Saket_Agarwal
we have this lifting fixture used to lift floor assemblies of the train. The fixture has four side arms which rests on the beam structure. There is no connection between the two, they are just resting and transferring the vertical load. How should I define the contact between the two? everything is modelled using shell elements.
1 - 1 of 11
    hello @Saket_Agarwal ,
    may I ask you which solver are you using? Also would it be possible to share a screenshot? That would help us to provide you relevant tips
    Best Regards,
    Michael
