Can the function I describe below be implemented in the API?
User: "bigshow4399"
Altair Community Member
Updated by Jocelyn
"Can the function I describe below be implemented in the API?
The volume forces acting on the particles in the six directions: up, down, left, right, forward, and backward.
If a bond is generated in any of these directions, the volume force in that direction disappears.
When the bond breaks, the volume force in that direction reappears."
1 - 1 of 11
    User: "PrasadAvilala"
    Accepted Answer
    Hi ,
    Can you please elaborate about what is volume force?
    Also, let you know how the bond model works, as long as bond is not broken bond model is in action for force calculation, once the bond broken then the base model is used to calculate further interactions.
    Thanks,
    Prasad A
