Hi all,
I am busy working on some beam-bending calculations in ESAComp. Compared to my hand calculations, the EI_y value from ESAComp was different. On further investigations, it seems ESAComp is doing E^f_x * Iy while I am doing E^f_y * Iy.
My understanding was that the flexural terms the 2.5D analaysis generates are felxure about their sub-script axis, therefore I have been using E^f_y as for a beam with a cross-section in z-y and lenght along x, this is the flexure term I need when applying a load at the end of the beam along z.
I know the likelihood of ESAComp being wrong about this calculation is low, but if that isn't the case, could someone please explain why using the E^f_x term is correct when the beam would not be bending about the x-axis?
Best,
Andreas
