electrostatic model, what should I do if I want th e particles to be attracted to each other, I use the same particle material and the particle size is set according to a normal distribution particles
You need to ensure the different particles have a different Charge value which you set in the Factory.
https://help.altair.com/edem/topics/creator_tree_physics/the_electrostatics_model_r.htm
If one particle has +ve charge and one -ve charge they will be attracted to each other, if they both have the same +ve or -ve then they will be repulsed.
Regards
Stephen
Thanks, i find it
