I am studying the dmigmod and reloc of the superelem. Do all constraints of the superelem and relocation must be exactly the same? If the copied one is different from the original one, how to restrict it?Through connect cards? I can't open the connect card here, showing equivalence dont supported. Therefore, the repositioned superelement is lack of constraint, resulting in almost all stress analysis errors. I used optistuct calculation. Thank you for your help. Thank you.
