I ama trying Physics AI for first time. after importing the data set it shows pending status and doesn't move on. Currently getting stuck here. What could be the issue?
Hi @Ajinkya_Badkas,
The same issue was reported by your colleague Ritesh Kumar as well.
We are providing the same recommendations provided to you as well.
First recommendation:
Kindly test the same & let us know if the first set of recommendations help in resolving the issue.
In case, the issue still exists, then, kindly let us know & we will provide the second set of recommendations which requires you to have a 'admin' login.
Many thanks.
Kind Regards
Garima Singh
