Hi Everyone,
I have been trying to implement the Bonded-Particle contact model (v3.5.0) API provided by EDEM (from its previous EDEMSimulation forums), then it works fine. But when I tried to import the geometry model(.mesh file), the bead chain model created using the (v3.5.0)API broke into particles when it collided with the geometry model I imported.In contrast, when I simply use the built-in Bonding V2 model against the same parameters as for API, then it works fine.
Any suggestions, what could be the potential issue with that?
Thank you.
Best regards,
Bai
