Motionsolve event entity editor can't be edit
User: "Adamz"
Altair Community Member
I'm trying to applied a custom event in Motion solve. I'm facing an issue—when I attempt to view the Altair entity editor, nothing is displayed. As a result, I am unable to modify the event in entity editor.
Thank you in advance for your help.
Have a nice day!
1 - 3 of 31
    User: "GTT Adam"
    Hi @Adamz,
    Does the Entity Editor display data for other entities, like the Altair Driver Model? Try selecting the Driver Model to see if the data fields appear. If they do, then try selecting the event again.
    Hope this helps!
    Adam Reid
    User: "Adamz"
    OP
    Yes, the entity editor display data for other entities but it doesn't display on event and Altair Driver Model only, i tried to select other entities then try selecting the event again, but still nothing appear.
    User: "GTT Adam"
    Hi @Adamz,
    If you are still having issues, then please try the following:
    • Toggle the Entity Browser on and off
    • Run the HWCleanup Tool to reset HyperMesh Desktop preferences
      • Found here: C:\Program Files\Altair\2024.1\hwdesktop\utility\HWCleanup\HyperworksWindowsCleanup.bat
    Hope this helps!
    Adam Reid
