I have some questions about the image above (topology revision options).
When should these options be used?
I don't know how to test their functions."
Let me know if you'd like a detailed explanation of these options!
hello @asdfsdfasdfasdfasdf ,
in the classic UI, these option rules remeshing scenarios in case you edit after mesh a geometry that is associated to a mesh.
If you choose remesh, then any change to the associated CAD will lead to a remesh of the affected surface(s)
In the new UI, this option is under Meshing preferences → CAD Topology Revision:
Best Regards,
Michael
thanks a lot!
