how to plot contact chain in EDEM
Hi QinHe,
Can you please go through the below forum link which helps to address your query
Force chains — Altair Community
Thanks,
Prasad A
Hi, just to note if you go to the EDEM Analyst. Select Particles and de-select 'Display All' then choose Apply All (you may have to scroll down)
Then go to Contacts and choose All-All or change to Particle-Particle/Particle-Geometry as required and then select 'Display Contacts'. You can colour these by your chosen measure.
Regards
Stephen
Hi, you can use the Contact Opacity to make it transparant:
Or use a clipping plane/slice to cut the model:
https://community.altair.com/community?id=kb_article_view&sysparm_article=KB0121981
page not found in this link
Yes, that shows a section, I was hoping to make it half transparent to see the whole.
