I'm having a problem with Altair Inspire when I want to analyze
a movement. The program works correctly as long as there is
NO contact set between parts (both as structural or joint contact). If there are any contacts the program closes automatically when pressing the motion run button.
My PC has all the technical requirements, and the graphs card is updated (NVIDIA GeForce RTX 3060). This same file on other computers can be opened and analyzed with contacts normally. I have tried installing and uninstalling, even other versions and I still have the same problem.
I hope you can help me, thank you very much for your time.
