Hi. i am working with a problem about Fuel tank. i am trying to simulate the motion of the flulid inside the tank when moving. I also want to know the interaction between the tank and fuel. So base on these results i could find out the cause of crack, break line that appear on my fuel tank after a short time using. Which solver i should use to do, Does anyone have documents or instruction for this kind of problem. Thanks alot
