Hello
How can I rotate stairs or any other room in wall man so I can represent my building properly?
Hello @alag88,
First you need to select the given object (selected objects are highlighted in red). You can then perform some geometric operations such as move and rotate it. After selecting, from the Objects menu > Rotate Selected Objects > you specify the Rotation Center as well as the Rotation Axes.
I hope this helps!
Zeina
