Hello! I am still pretty new to altair hypermesh CFD. So while I was trying to run a simulation on my car team's model, my solution ratio was not converging at all.
On previous simulation runs, I've been able to successfully run sims that take about 30-60 minutes. However, this time my solution ratio and simulation wouldn't work after running the sim for 4+ hours.
For reference, I am using incompressible flow with a steady-state model of K-Omega. I've also attached the plot manager.
I would greatly appreciate any tips on running this simulation successfully. I also tried decreasing the volume meshing size from 0.75 to 0.25 but had no luck.
