hi,
I am trying to write a hole mates detection tool.
Below is the main code I used
hm_holedetectioninit *createmark elems 1 'displayed' hm_holedetectionsetentities elems 1 hm_holedetectionsetholeparams hole_shape=31 hm_holedetectionfindholes 1 hm_holedetectionfindmates max_distance=10 hm_holedetectiongetmatedetails 1
As you can see, I used option 'max_distance' to limit the maximum distance between holes in a mate to be found. The code run without any issue.
The problem is the returned result includes hole mates with the distance > 10. Even when I tried to translate the mesh to make the distance much greater, the program still returned that hole mate.
The left hole mate has distance=40, the right one has distance=10. Both are identified as hole mates with option max_distance=10
Am I doing anything wrong code??. Appreciate your help!
