Hi everyone, just installed Altair Inspire, my drivers are up to date but can't get Inspire to start up, anyone had this issue?
Hi @Hector_G,
Is Inspire 2024.1 installed in the default directory? If it is not in a local directory, such as on OneDrive, it may not launch properly.
Please confirm that it is installed like the following: C:\Program Files\Altair\2024.1\Inspire2024.1
Hope this helps!
Adam Reid
I installed on default directory, in the past i would remove the Nvidia Drivers shown in the image below and it would work, need new solutions because some other apps demand these drivers
So the solution looks to be deactivating those extra drivers.
Can the other applications function without the extra drivers?
I'm using Unreal Engine aswel so i can't remove Nvidia drivers anymore
