Hello, I've keep having trouble with exporting node value like magnetic vector potential, magnetic field. (I attached the example in the below.)
I've attempted to find functional tool which enable to export post processing results, but I failed.
Only I found is that I can get the node value with sensor.
But I have to get thousands of nodes' value, so I don't think It works for me.
As I searched, someone resolved this problem with code, so If you have a code for this problem, please share with me.
It'll be better with excel file exporting.
Thank you.
