What is the constraint i can use for optimization of casted components to reduce the material in thickness direction starting from mid section
Hi @Siva99899,
You can optimize the topology of parts through the minimizing of mass using the following tutorial:
Tutorial: Optimizing Topology - Minimizing Mass
You can also optimize the gauge of parts using the following tutorial:
Tutorial: Optimizing Gauge
Hope this helps!
Adam Reid
