Hello, I imported some kinematic values from EDEM and used optimization and DOE to check.
In the result, the changing of values didn't work.(I checked that the changing of those three values have effect on Lacey)
How can I solve this problem?
I just test with simple rotating mixing, it happened too.
Thank you for your interesting.
I'm using 2022.2 versions
