Hi everyone,  can someone please help me solve this problem.  In the attached example the data the first 3 lines shows the component and the description for that component in the line above and below it.  There are a few cases like this in my dataset and also a case where the description is the line in middle and the component in the line above and below this line (as seen in the last 3 lines in the example).  Can someone help with the process to fix this problem in my data?
Thank you
