Hello, Is NVIDIA A4000 GPU card compatible with using physicsAI? Thanks in advance.
hi, yes it is. You need to install both CUDA toolkit and CUDNN in order to activate the GPU usage for the trainings of pAI
refer to the help FAQ section:
https://help.altair.com/hwdesktop/hwx/topics/reference/extensions/faq_r.htm
Hi Cimes,
To understand the process involved in integrating GPU for PhysicsAI model training, kindly refer the below blog which has all the details related to GPU specifications such as (having Compute Capability 6.0), supported CUDA tool kit & CUDANN versions etc. to help you get started.
Many thanks.
Kind Regards
Garima Singh
