May I know how the curve based value in constraint panel works?? What is it used for ??
It may be used to define variable load
if OS can utilize it, you will see information about that in card information of relevant load types
(SPC, SPCD do not, but others may)
It may be used to define variable load if OS can utilize it, you will see information about that in card information of relevant load types (SPC, SPCD do not, but others may)
Especially for MBD related.
Thank you very much for your help
