How to simulate for a series of antenna.azimuth angles in api
User: "Coco"
Altair Community Member
Hello, I was trying to simulate with the api of WinPro. When it comes to define the antenna, I wonder if there is a way to input a vector so that multiple angles can be simulated at once. I noticed the variable WinPropAntenna.Azimuth is defined as a double and there's no exmple of it being a vector in the handbook.
Thanks in advance.
1 - 1 of 11
    User: "Jaehoon"
    Accepted Answer
    Hello Coco,
    You can define only one orientation (set of azimuth and downtilt) per Tx antenna and simulation.
    To consider multiple antenna directions you either need to define multiple Tx antennas with corresponding orientations in the project, or change the orientation of the single Tx antenna after each simulation run.
    Best regards,
    Jaehoon
