The zip file that should contain the files for Exercise 5G in the course was attached incorrectly, as can be seen in the screenshot below.
The PDF is correct (5G), but the zip is wrong (5F).
Hi Plinio!
Thank you for bringing this to our attention. Sorry for the inconvenience caused. We are addressing this issue to ensure the correct files are accessible as soon as possible. I'll follow up once this is solved. Thank you.
Hi @Plinio Savietto! You should now find the correct files, related to the specific exercise for this Module. Thank you!
Sorry for the late reply. I was on vacation.
Thank you very much for the fix, Daniela!
Sorry for the late reply. I was on vacation. Thank you very much for the fix, Daniela!
Hi Plinio! No worries at all! I'm glad to hear the fix worked for you. If you need further assistance, feel free to reach out. Thanks for your message!
