I am unable to view the full window of the Resultant Force and Moment tab. How to expand the tab?
If you use HyperMesh Desktop, there is not this issue you can close tab very quickly. But in HyperMesh it's a little hard here many tab can drag and drop on graphic area and then close. For exp. see below picture. But Resultant Force and Moment tab can't drag and drop. My suggest you should delete template files in documents. I can't think of any other way
