How to resolve the join operator problem?
emilie
New Altair Community Member
Hi I am a beginner, I encountered join operator problem. After I installed extensions, my join operator still cannot show right port data except the id attribute, how to fix this problem? Thanks
Best Answer
Hello Roland You're genius. This is my first time seeking help online, I am impressive with your timeliness of your response and your unbelievable professional skill. Thank you so much!0
Hi @emilie
Could you possibly post screenshots of what you're seeing, and if possible share the datasets? Otherwise, I'd suggest at looking at the Join operator tutorials to understand where the possible issues are coming from.
Best,
Roland0 -
Hi Roland
Thank you for your reply. Here are my screenshots. The first one is left port input data, the second one is the right port input data, then the process and the output data. The output data only shows the id attribute from right port without other attributes, that's my problem as I'd like to compare the LOF_outlier from left port and the Distance_outlier from the right port. I already installed extensions. I didn't get any inspiration from the tutorial. Can you identify the reason for me? Thanks!
Emilie
0 -
Hi @emilie,
Do the variables of interest in the two tables have the same name? RapidMiner doesn't allow columns with the same name and I can see on the Join operator you have the option ticked on to remove double attributes, rather than rename.
Best,
Roland0 -
They left and right port are from the same dataset, they have same name except the generated outlier by detect outlier (LOF) and detect outlier (Distances) which are renamed. I only need the LOF_outlier and Distances_outlier.0
Hi @emilie,
I have discovered the cause by building a small sample. Because the columns of interest are classed as metadata (shown in yellow), only the metadata columns from the left table are carried forward. You can get round this by manually setting the columns to be regular or labels with a Set Role operator before you use the Join. I've attached my example underneath - let me know if this doesn't make sense.
Best,
Roland<?xml version="1.0" encoding="UTF-8"?><process version="10.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="10.3.001" expanded="true" name="Process" origin="GENERATED_TUTORIAL">
<process expanded="true">
<operator activated="true" class="subprocess" compatibility="10.3.001" expanded="true" height="82" name="Generate DataSet" origin="GENERATED_TUTORIAL" width="90" x="45" y="34">
<operator activated="true" class="utility:create_exampleset" compatibility="10.3.001" expanded="true" height="68" name="Create ExampleSet" origin="GENERATED_TUTORIAL" width="90" x="179" y="34">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="x y part 0.45660137634625386 0.43280640922410835 Head 0.6113784672224188 0.5286245988894975 Head 0.45029897412145387 0.7116061205092745 Head 0.6390150501606866 0.46074398219372076 Head 0.6289567839292338 0.32346951478531516 Head 0.5662104392361843 0.289357728041304 Head 0.5676530359179894 0.29547265797376954 Head 0.43602399117606827 0.4157757274892156 Head 0.5454137939219365 0.36750178191490135 Head 0.4394528077596546 0.5478674292772121 Head 0.512200437106122 0.500864646508404 Head 0.3917587782134365 0.6103473035285875 Head 0.5218570283765972 0.5769060811333763 Head 0.7194189575585879 0.43648093863144677 Head 0.2995329322777752 0.6230627270405613 Head 0.4982241475102956 0.42839983794125985 Head 0.2740522921447801 0.4804320598631085 Head 0.38284021717487404 0.5440688862962566 Head 0.4249231989421871 0.284825727537369 Head 0.5207238207675212 0.32542733595644696 Head 0.44329557666585284 0.32697891986066585 Head 0.39882121731993425 0.44917757772100975 Head 0.5043499801956989 0.31104972990661883 Head 0.6418316378383897 0.44634230241629513 Head 0.3875139053807079 0.5835776682759641 Head 0.3939936115953249 0.4355492315286958 Head 0.5310410091841999 0.6295649641551255 Head 0.6888968092469115 0.5241631381654697 Head 0.6493962308649859 0.37410916300714764 Head 0.46558804569679024 0.3808260349477101 Head 0.6258946158877843 0.29786152832143475 Head 0.33422593969522363 0.4716084824524596 Head 0.3668006741594324 0.7098112476478706 Head 0.7416277782794454 0.5889910190948651 Head 0.38272263131699585 0.452737367638514 Head 0.56506329156323 0.4368807019054587 Head 0.3507596663956172 0.4731503428096154 Head 0.5681429924399365 0.42284600051634724 Head 0.4982887847983077 0.3891165629058462 Head 0.4364283715014795 0.692301105545165 Head 0.6037254126431655 0.46839656019105724 Head 0.5888498769597843 0.47524402811514127 Head 0.6989962241574786 0.39153609364235065 Head 0.6752421809738202 0.5665200576628142 Head 0.6455623948444207 0.4575869722287391 Head 0.4155274258102421 0.5261488358815203 Head 0.29194678962167875 0.4272334801227161 Head 0.4375613322732245 0.6446881351198951 Head 0.33345440081047545 0.4690126900207642 Head 0.5434853498540486 0.5575180098090339 Head 0.4411923952597462 0.5154128811111293 Head 0.5706964819958329 0.6262959368064891 Head 0.7065470571054172 0.3526615357856453 Head 0.4431214691109642 0.6322492132512522 Head 0.323144615700802 0.5142624100259803 Head 0.7009787144079658 0.6058330298954564 Head 0.6794405111786648 0.33386383983683265 Head 0.7159374380776726 0.5369769299381377 Head 0.47975236292326595 0.7007875282162737 Head 0.41003838698089295 0.5099887518902678 Head 0.49008612485006625 0.6294229305694207 Head 0.46603747603182555 0.6268512537813131 Head 0.32351200563321114 0.6393495801876143 Head 0.4473375193351228 0.7348324501821877 Head 0.5556571320867622 0.5715022879444677 Head 0.5707049148610202 0.33224836461163654 Head 0.6227812899148043 0.3306931377284241 Head 0.6006889225245693 0.2928147023531954 Head 0.6676542569289109 0.5752724418322568 Head 0.309970327833062 0.45265291703067895 Head 0.6127630910463642 0.5027568608385389 Head 0.32860350692925033 0.4413129371744251 Head 0.30656537501122727 0.35196144277089036 Head 0.6051765579581507 0.4821492917720065 Head 0.440146903930251 0.495593601024648 Head 0.598144530201707 0.5532603752903262 Head 0.44347199035029516 0.4622535936838886 Head 0.422174903173814 0.34103901488291244 Head 0.45550648740195465 0.41171202752594527 Head 0.4720555872309712 0.7165683667235623 Head 0.7347191848708641 0.5758536326400511 Head 0.5155381256468614 0.7245756845076422 Head 0.3273149601044746 0.6263807471208405 Head 0.4346341375571578 0.3634158158782626 Head 0.38319743027975633 0.2762100009308178 Head 0.48022262821967227 0.39871803725628563 Head 0.5379614400606375 0.6077396909730114 Head 0.31976325998106114 0.6241915643427768 Head 0.5284666588142557 0.5480244917619645 Head 0.47710199684411575 0.40228069309626585 Head 0.33331807289623916 0.46849763185945303 Head 0.6753842036454221 0.31970273813787053 Head 0.40951456007576653 0.42842739961973997 Head 0.5006618827477158 0.6265923168364407 Head 0.49827763183980106 0.5382010339612469 Head 0.5012632137589963 0.5748491652989149 Head 0.68924092353326 0.38632021585199633 Head 0.7446366283207957 0.4865794985985416 Head 0.5477306196567974 0.668460274663 Head 0.39153963750374315 0.5776294199926051 Head 0.557290307940882 0.6178822878859911 Head 0.5416042277812119 0.47991525488202486 Head 0.5137967253936864 0.6285313418967632 Head 0.4791669907632519 0.6495911839030653 Head 0.6720370220970937 0.4040964379295322 Head 0.3958227884361515 0.6588452624261568 Head 0.5787426768538191 0.6941884431469565 Head 0.6058904881765098 0.5303936494898217 Head 0.407653340954602 0.44070720087977705 Head 0.42722756534718975 0.6185064737597324 Head 0.516001237408541 0.4585304151965233 Head 0.5913356730889696 0.26544906819330893 Head 0.4862318964328004 0.4635469791701871 Head 0.4114364122202755 0.4044955392669422 Head 0.4101348255428155 0.49464707734714325 Head 0.4679994292151898 0.4128731663431996 Head 0.5819559278781021 0.687203291527696 Head 0.6793080502468297 0.38356312225629596 Head 0.38937054474971433 0.5734057037038085 Head 0.49606383258716635 0.3290899150196019 Head 0.6781048209663016 0.33292748108390435 Head 0.3496903121642816 0.4329933992146022 Head 0.28538727428959565 0.44406197703937333 Head 0.4802810307277785 0.7465574165966149 Head 0.2758683060347048 0.42493086482223386 Head 0.7165964637807317 0.4961768132521903 Head 0.6275690079206528 0.5523467224319585 Head 0.30863520005670103 0.6065060017631401 Head 0.5184350739403722 0.6255933181594546 Head 0.3252727704249059 0.518663878690165 Head 0.5364211032665399 0.3192852795617066 Head 0.6360506427122014 0.452177164199903 Head 0.6550836751096591 0.6737695414449972 Head 0.381049286997603 0.3442848645161163 Head 0.6977418201849414 0.5002854794895334 Head 0.29387974001507766 0.5660318782525734 Head 0.3950573073741327 0.30776141086320624 Head 0.5875283142332661 0.5029850439760691 Head 0.47577243578762335 0.6571162960275716 Head 0.5765913115106007 0.6073630568836432 Head 0.43120782286536896 0.4536048393809892 Head 0.4271374008377422 0.7324222423451453 Head 0.509538178207134 0.6931777163283148 Head 0.5181698331845648 0.5111409992566154 Head 0.44864558562432355 0.6811903182476917 Head 0.682341733951336 0.43078415493021127 Head 0.5309666065607501 0.2985289265625874 Head 0.600897799997153 0.6635429624194095 Head 0.46780169318472314 0.3947836158292342 Head 0.5915644139504792 0.3850652622739119 Head 0.387755003704134 0.6797111393353542 Head 0.36782453531478027 0.4372164861268705 Head 0.43639037701069394 0.4112832888808655 Head 0.626036706904056 0.4330240031551585 Head 0.4776430480397612 0.717473875201391 Head 0.5054771793503865 0.5395424282031024 Head 0.5221943178984508 0.7031808147941978 Head 0.4717768997272872 0.6064647504959523 Head 0.5050531711150169 0.6694099945514911 Head 0.650228341055716 0.5706997864367978 Head 0.3096170370177286 0.526590983167117 Head 0.6249509070898287 0.44761019842893723 Head 0.5053620701269804 0.6750690635122293 Head 0.6235230129146608 0.6421753304125937 Head 0.5106216733301224 0.41911915802469024 Head 0.29111887670561115 0.3624646302450098 Head 0.34135204212954423 0.4836897378719605 Head 0.6162899699681502 0.46263925715201104 Head 0.7068606124650494 0.46130772099304174 Head 0.518605160378907 0.37252647303440034 Head 0.6819633448943572 0.573433213976195 Head 0.5663578499358706 0.49135390567741366 Head 0.7086202064025585 0.41844781677046694 Head 0.5249692372285568 0.485610262030015 Head 0.6615332034083491 0.5495324580384817 Head 0.46567523869648914 0.5669969664558905 Head 0.6411788036353628 0.4686061791825734 Head 0.4354437851788592 0.6211545627513583 Head 0.3581252743826723 0.4777912813178678 Head 0.44937310198209257 0.4881941150533161 Head 0.36399287493228166 0.6032079773689988 Head 0.4120218915505539 0.3893285016733924 Head 0.5890047243886416 0.726746495955555 Head 0.4313267952812512 0.5750655042335979 Head 0.4927077492482129 0.38147483787457936 Head 0.5809203379333364 0.27920133592307494 Head 0.6149777466040518 0.4894293635413928 Head 0.4908517743150437 0.3637882120895225 Head 0.41264041587823297 0.41225177314572403 Head 0.3253529896251357 0.3504070739523616 Head 0.6974678628306086 0.4939221539103153 Head 0.4967336591637833 0.7059962656241111 Head 0.3685019338280463 0.5382408243577209 Head 0.3778348723181266 0.33470062886484636 Head 0.49211704225348335 0.2633016877556674 Head 0.40113010234854113 0.3249963592946038 Head 0.6886960489176914 0.6418252133877184 Head 0.44149533809771346 0.2739239915645413 Head 0.44458360726584134 0.40254557139333424 Head 0.6467627630109937 0.689444722536442 Head 0.49521829879934565 0.5429004259715249 Head 0.6197171351587627 0.6938126277047257 Head 0.2973495363920637 0.48308248414547883 Head 0.6209889659198802 0.49661943645755685 Head 0.5684222384796382 0.32004613720261177 Head 0.48084197943805607 0.38070850868584616 Head 0.5132405090658441 0.4690018473807536 Head 0.6977312894835461 0.39772196918136554 Head 0.46275715986772836 0.5465254622670109 Head 0.7311613067298663 0.47433638523777666 Head 0.4507442079334246 0.30905590754281775 Head 0.4614853335162101 0.45354716893263375 Head 0.6435018480838316 0.6463838992670885 Head 0.3300975326325553 0.61429800117587 Head 0.6028701592288027 0.6008484200713187 Head 0.4347701798526803 0.557562736730373 Head 0.6932948946988342 0.5654534594730938 Head 0.5247572213790491 0.26401207215943967 Head 0.5002917903066961 0.5418692345518223 Head 0.6522206886764839 0.6617862064183648 Head 0.2902584810634696 0.35073348437709656 Head 0.5071687450460225 0.5064850209229907 Head 0.2917686387906876 0.5758692207316308 Head 0.3755203166446687 0.6898760992517088 Head 0.6173535815217863 0.5281875766332944 Head 0.631710072257924 0.5795536341679328 Head 0.40893966208118576 0.4983293218748703 Head 0.6812524582312698 0.31644405636050704 Head 0.4407453623940024 0.5196531804037615 Head 0.37284220557890724 0.4718757302380132 Head 0.41194253633769695 0.4918369529267401 Head 0.743425497014074 0.43616922159939475 Head 0.4942279047060185 0.6133456159749187 Head 0.5935990874065795 0.41016038620431844 Head 0.5729702930852463 0.728394506497188 Head 0.6591024621232009 0.6408554187767201 Head 0.609492664166897 0.6063615320484372 Head 0.48806697616378103 0.5180426495602906 Head 0.5725696758131162 0.4762827013233272 Head 0.4355175323467955 0.5279784453659533 Head 0.6539212330228087 0.46335062554135026 Head 0.5068255999089359 0.5010647442959388 Head 0.4947431869026147 0.5597150804477188 Head 0.4974167815731843 0.40614885020574676 Head 0.5233871269725687 0.341093611151546 Head 0.46459992800618827 0.5291033620154328 Head 0.5944024530455814 0.6057524678883506 Head 0.5677375256034707 0.3454778041423724 Head 0.6120606266203569 0.3484377583462397 Head 0.27728901699058806 0.48203144582259505 Head 0.33919818777823585 0.6508366786305482 Head 0.41418250615709484 0.5820433717684208 Head 0.46731998488268855 0.57399981287557 Head 0.43897421752365273 0.39141139582977835 Head 0.4165562579890373 0.5855165706078677 Head 0.4163655211429044 0.35800944275982216 Head 0.4472267728778566 0.3239469279293801 Head 0.5529486594119973 0.6117575097364949 Head 0.3860771082109893 0.5584592017837059 Head 0.746576954842598 0.4852447791533015 Head 0.6787683190354972 0.544416694963726 Head 0.4417443374743319 0.5304243162428341 Head 0.7041355812071616 0.42907835126741445 Head 0.6025872583526563 0.6519178863077449 Head 0.4515006741729511 0.5494168152052004 Head 0.34406769499995704 0.31452273995412067 Head 0.6571664530758328 0.3395494139819467 Head 0.5391133985130727 0.4030198290550403 Head 0.5785911585761276 0.2756801334945491 Head 0.7517526656172895 0.4980941672696096 Head 0.6116232439393944 0.35471442426755717 Head 0.44394105422327373 0.5891244340193036 Head 0.5364752663717447 0.4694347928377997 Head 0.6375590914200824 0.5847092832713302 Head 0.32268111908104147 0.46658768216650875 Head 0.7093289532125356 0.636966691161416 Head 0.41670674548454156 0.40979298046661683 Head 0.40226843709696475 0.44601176413907095 Head 0.6312411617947771 0.45662127468333275 Head 0.5138729896078243 0.29507230737868534 Head 0.5630681951826686 0.6915233346477797 Head 0.3540846764255108 0.4841694760329867 Head 0.5264648654399303 0.4443834265792434 Head 0.5457131844740668 0.5895896361495174 Head 0.3455796836575118 0.451227266339269 Head 0.6507143465614921 0.63649523744681 Head 0.7425328608722306 0.5347125144436418 Head 0.6823273195034794 0.6352458367411182 Head 0.5081344429412513 0.5635050450437091 Head 0.5221079576856864 0.38781976501469645 Head 0.22251831991489018 0.7883298714240449 Ear_left 0.14596680282946534 0.7632310055814474 Ear_left 0.23749944219723773 0.7655984146207966 Ear_left 0.1980285850674685 0.7098982570929543 Ear_left 0.2616646827795952 0.6704418747075763 Ear_left 0.203041695250713 0.7347975140559748 Ear_left 0.3064904159455227 0.6902919556360958 Ear_left 0.2842777643038236 0.738365511007765 Ear_left 0.20530967314622395 0.7428170097694976 Ear_left 0.20771837372789004 0.7507873026800568 Ear_left 0.23879859471892556 0.7543122358021094 Ear_left 0.21801957755241635 0.7186034168830753 Ear_left 0.21524461099141762 0.7711917048187262 Ear_left 0.2039350838715879 0.7803596247355663 Ear_left 0.26075720217685444 0.718573999028452 Ear_left 0.293135146073639 0.714649474646771 Ear_left 0.20399614466425392 0.8184813524802571 Ear_left 0.28035680692780035 0.7161289758113678 Ear_left 0.22244794366175197 0.6727625517281877 Ear_left 0.1879572805347128 0.7862968000937579 Ear_left 0.28729744918040523 0.7945900385438784 Ear_left 0.2712753218265971 0.752179949875212 Ear_left 0.25260232004573774 0.7375688203243906 Ear_left 0.2092131026735191 0.7543484627335988 Ear_left 0.27527637261962035 0.7853181287824482 Ear_left 0.20290811368806627 0.7051821711673277 Ear_left 0.23755908729032657 0.8251065576211906 Ear_left 0.19643659936725835 0.7305112040483317 Ear_left 0.2514615416001959 0.7983455398050048 Ear_left 0.2292728118427541 0.7370013770311333 Ear_left 0.29832254625051435 0.7609297935421809 Ear_left 0.20296773383981564 0.7984580104619133 Ear_left 0.24398690269160286 0.8032512717246497 Ear_left 0.2823454381870513 0.6507218459719635 Ear_left 0.26055383370285917 0.7235272860746765 Ear_left 0.2687578250941205 0.7243688939663058 Ear_left 0.30638096553920613 0.7899582016439562 Ear_left 0.26470437697816573 0.7615201266645316 Ear_left 0.18298967448118103 0.7278944895737949 Ear_left 0.2170246393794728 0.7368279607345486 Ear_left 0.18182398704466007 0.7740302445527997 Ear_left 0.3065593255916551 0.7337959330515907 Ear_left 0.23527779023288595 0.7380422083283124 Ear_left 0.31000902581983353 0.7885794583567364 Ear_left 0.21034555806799418 0.6874932243575869 Ear_left 0.25411247060277425 0.7656493948354395 Ear_left 0.27814902664247004 0.7271079377554931 Ear_left 0.26608295583730507 0.7915967608107661 Ear_left 0.30032996652105604 0.7234573857809834 Ear_left 0.18152151643851627 0.7095338322497738 Ear_left 0.2512776247287444 0.7438694999329588 Ear_left 0.30986265676342345 0.7775360767316855 Ear_left 0.23074597881615913 0.6824100891725686 Ear_left 0.21569880839919162 0.7620046924524896 Ear_left 0.18351795509367025 0.7981412970500236 Ear_left 0.20625837001259215 0.7691560734137575 Ear_left 0.2947503737253423 0.7486847327436937 Ear_left 0.32811448779324703 0.8104480471833705 Ear_left 0.208239343383985 0.7387634028043626 Ear_left 0.23055874576730068 0.6949130653293023 Ear_left 0.24439870503634276 0.765492637542115 Ear_left 0.2866910854803799 0.7614094808432198 Ear_left 0.3014838543031903 0.7034441483006492 Ear_left 0.25282448358490983 0.7755234070996266 Ear_left 0.3220857054082107 0.7600928123854157 Ear_left 0.2557890614036615 0.749439300160098 Ear_left 0.17195783502929168 0.7368635502701839 Ear_left 0.18802792946329955 0.7244508057995779 Ear_left 0.1693845891719489 0.7154201808129301 Ear_left 0.18960171748102256 0.6820443275786829 Ear_left 0.2540901461651084 0.7916198603119513 Ear_left 0.2575684992783643 0.7434440050549689 Ear_left 0.21711019410354682 0.7293907077000309 Ear_left 0.22862637173035064 0.7667573619367998 Ear_left 0.25254817011715774 0.7898072848574761 Ear_left 0.30738378186990223 0.7015168146141113 Ear_left 0.2819275324554639 0.7689053884387266 Ear_left 0.26948071444154426 0.8373758527603316 Ear_left 0.258821822279201 0.725529628631154 Ear_left 0.24213541161565805 0.820011553112265 Ear_left 0.2629165269874901 0.7036678040195118 Ear_left 0.25468844356494813 0.7614163539866831 Ear_left 0.23745015069634573 0.7267085856031248 Ear_left 0.3040010147972316 0.8009067304298891 Ear_left 0.2579580823160971 0.7189356681450992 Ear_left 0.2663458716267545 0.7520018097620143 Ear_left 0.2986434311642774 0.7002088979934473 Ear_left 0.2592484700407562 0.7763635575221557 Ear_left 0.20599359133993891 0.7400399815310459 Ear_left 0.2178829081972778 0.7403140181632161 Ear_left 0.3179576779430139 0.749793212710529 Ear_left 0.21382856749133544 0.7943446931222934 Ear_left 0.2557675632363441 0.694139636565999 Ear_left 0.2522237138681524 0.7943940006827237 Ear_left 0.30021772312881323 0.743089979045272 Ear_left 0.1970866600117869 0.7954764320973517 Ear_left 0.31876246776325046 0.7669449786264386 Ear_left 0.2202104218437173 0.8428793976571253 Ear_left 0.35648189808486724 0.782707269261588 Ear_left 0.1809722095110372 0.7812986916049908 Ear_left 0.8377997370239522 0.7538358880610266 Ear_right 0.7294538573365863 0.779583670283009 Ear_right 0.6806521891032632 0.7177689348083449 Ear_right 0.7638809829937171 0.6572282090651652 Ear_right 0.7808853187516883 0.6592734947925624 Ear_right 0.8311746997903773 0.7262206255047086 Ear_right 0.743277821809469 0.6841029232826228 Ear_right 0.680688321346238 0.7475368639764006 Ear_right 0.8506187347587049 0.7990803699876275 Ear_right 0.7569000845699596 0.7952538516155098 Ear_right 0.7630899449816186 0.6852925401504006 Ear_right 0.7087331262670795 0.7655352223855434 Ear_right 0.7031486691547949 0.799646589897552 Ear_right 0.6956869262957491 0.7590079149145048 Ear_right 0.770220159307569 0.749528422333163 Ear_right 0.7023711448714501 0.7689249857718555 Ear_right 0.7534022960618623 0.7993679677299006 Ear_right 0.6892903823233598 0.7348762966442893 Ear_right 0.7651082962482073 0.6747331730235104 Ear_right 0.7052152644415275 0.6768256571756351 Ear_right 0.7116156172064612 0.8174867359631751 Ear_right 0.7113519692867732 0.7425940366695418 Ear_right 0.7064273764082712 0.7960264143806072 Ear_right 0.7940793434401193 0.7073379545190814 Ear_right 0.8237151064798245 0.6794732313853846 Ear_right 0.7984657574489835 0.7001463509025435 Ear_right 0.7665757626244889 0.7566684229513448 Ear_right 0.7258691046078412 0.6646061045396762 Ear_right 0.7541304825238758 0.7238597313052797 Ear_right 0.7448782161551408 0.7394726189785576 Ear_right 0.7872023861255228 0.8173254155580306 Ear_right 0.7830924890472047 0.7316558161430998 Ear_right 0.7651971076541776 0.7692942812179941 Ear_right 0.7520106617132443 0.6876440874592499 Ear_right 0.7961459853569384 0.8393688643424051 Ear_right 0.650947500402311 0.7827968494187825 Ear_right 0.8012060759032598 0.7125634511545311 Ear_right 0.8061954950809548 0.7249522038232329 Ear_right 0.7275372076425105 0.6983388762514319 Ear_right 0.7728812723027745 0.7447321392738567 Ear_right 0.7802524132257377 0.7241470373979612 Ear_right 0.7699065301953223 0.7932185854129203 Ear_right 0.8123957636975742 0.7068171361169507 Ear_right 0.7304046011555516 0.7203249916761053 Ear_right 0.7056224589841433 0.774470827074884 Ear_right 0.7539382268261435 0.6953746090340507 Ear_right 0.7361881327956482 0.8203875876829062 Ear_right 0.7114013438444344 0.7294177739107931 Ear_right 0.7283903862822285 0.7400950365943004 Ear_right 0.8199224586670886 0.6624864411844861 Ear_right 0.6932931734763774 0.7483720380641234 Ear_right 0.7887163846530041 0.6553373804573515 Ear_right 0.7587346545400881 0.7143840276080937 Ear_right 0.7436451075785734 0.741107198751839 Ear_right 0.8399763413838327 0.7397512128037355 Ear_right 0.7195566103116555 0.7577349717565741 Ear_right 0.7387065607645802 0.7134573512536048 Ear_right 0.7585718200102338 0.7415011443924274 Ear_right 0.7260165987413801 0.7199155338102927 Ear_right 0.761046704494208 0.7666157837279917 Ear_right 0.7446390882313307 0.7705456687619933 Ear_right 0.8042376941620254 0.7934272658399564 Ear_right 0.843634259355262 0.723509085172378 Ear_right 0.7615764451888559 0.7735103681098081 Ear_right 0.7447471630813102 0.812900186453634 Ear_right 0.698756677231279 0.6992834559156688 Ear_right 0.836569858595413 0.7395273438740726 Ear_right 0.7055384167486035 0.8032623540731494 Ear_right 0.7405658451005331 0.7220012904983931 Ear_right 0.7568136057549706 0.7515402362252771 Ear_right 0.6756601639542467 0.7586515066960814 Ear_right 0.70971508636843 0.7124438097520422 Ear_right 0.667733846908035 0.6982389157975166 Ear_right 0.669730607148233 0.6950262325053415 Ear_right 0.6852754907203354 0.7810821546243205 Ear_right 0.7673394640297962 0.772005715794815 Ear_right 0.8116671981458425 0.7963891674181127 Ear_right 0.7353954902397984 0.7630575124298286 Ear_right 0.7304928242746523 0.7284849570246381 Ear_right 0.735357614154059 0.8135219075858261 Ear_right 0.829462601011989 0.7767929457052348 Ear_right 0.7476746137476434 0.7198597924007893 Ear_right 0.6927327403170797 0.6700023743441031 Ear_right 0.7522365172463774 0.6604606209567222 Ear_right 0.762326391564511 0.8024849472990617 Ear_right 0.6685866005871447 0.7817694635640924 Ear_right 0.7701084808001643 0.7051847879729983 Ear_right 0.7862989275963652 0.690065279670785 Ear_right 0.6830469136648829 0.764038216680348 Ear_right 0.6446792306915289 0.7639770872738367 Ear_right 0.7431589593477718 0.7725141972075193 Ear_right 0.7286601284351713 0.6666850344927256 Ear_right 0.7067359174595279 0.7877465869835184 Ear_right 0.7394233664811464 0.7860259050967145 Ear_right 0.749466614165472 0.7328131832071315 Ear_right 0.8248418521018915 0.7134157163726719 Ear_right 0.8239586646098369 0.7675190168773441 Ear_right 0.8155149407204317 0.7135170163641819 Ear_right 0.7856914234307533 0.6819138433217659 Ear_right 0.708266829777928 0.7612342280212532 Ear_right 0.290949977617754 0.8557666871174766 Noise 0.7500676018742642 0.897027660749859 Noise 0.040554927744786196 0.5072400792452862 Noise 0.8351619113805846 0.13894038814840037 Noise 0.17474033164278335 0.3636861115238198 Noise 0.15150612475114178 0.8765856628207388 Noise 0.8603082847506063 0.6338333996208041 Noise 0.8620825903226392 0.5918053842487218 Noise 0.9160298083819269 0.523390593285425 Noise 0.42732547274373656 0.8337665738193867 Noise"/>
<parameter key="column_separator" value=" "/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" class="set_role" compatibility="10.3.001" expanded="true" height="82" name="Set Role" origin="GENERATED_TUTORIAL" width="90" x="313" y="34">
<parameter key="attribute_name" value="part"/>
<parameter key="target_role" value="part"/>
<connect from_op="Create ExampleSet" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_port="out 1"/>
</process>
<description align="center" color="transparent" colored="false" width="126">Generate Mouse Data set</description>
<operator activated="true" class="blending:generate_id" compatibility="10.3.001" expanded="true" height="82" name="Generate ID" width="90" x="179" y="34">
<parameter key="create_nominal_ids" value="false"/>
<parameter key="offset" value="0"/>
<operator activated="true" class="detect_outlier_lof" compatibility="10.3.001" expanded="true" height="82" name="Detect Outlier (LOF)" width="90" x="313" y="34">
<parameter key="minimal_points_lower_bound" value="10"/>
<parameter key="minimal_points_upper_bound" value="20"/>
<parameter key="distance_function" value="euclidian distance"/>
<operator activated="true" class="anomalydetection:generate_anomaly_flag" compatibility="4.1.001" expanded="true" height="103" name="Generate Outlier Flag" width="90" x="514" y="34">
<parameter key="method" value="manual"/>
<parameter key="define_score_column" value="true"/>
<parameter key="score_column" value="outlier"/>
<parameter key="contamination_threshold" value="0.05"/>
<parameter key="manual_threshold" value="1.0"/>
<parameter key="zscore_threshold" value="3.0"/>
<operator activated="true" class="detect_outlier_distances" compatibility="10.3.001" expanded="true" height="82" name="Detect Outlier (Distances)" width="90" x="313" y="187">
<parameter key="number_of_neighbors" value="10"/>
<parameter key="number_of_outliers" value="10"/>
<operator activated="true" class="blending:set_role" compatibility="10.3.001" expanded="true" height="82" name="Set Role (2)" width="90" x="514" y="187">
<list key="set_roles">
<parameter key="outlier" value="regular"/>
</list>
<operator activated="true" class="concurrency:join" compatibility="10.3.001" expanded="true" height="82" name="Join" width="90" x="849" y="34">
<parameter key="remove_double_attributes" value="false"/>
<parameter key="join_type" value="inner"/>
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="id" value="id"/>
</list>
<parameter key="keep_both_join_attributes" value="false"/>
<connect from_op="Generate DataSet" from_port="out 1" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Detect Outlier (LOF)" to_port="example set input"/>
<connect from_op="Detect Outlier (LOF)" from_port="example set output" to_op="Generate Outlier Flag" to_port="example set"/>
<connect from_op="Detect Outlier (LOF)" from_port="original" to_op="Detect Outlier (Distances)" to_port="example set input"/>
<connect from_op="Generate Outlier Flag" from_port="example set" to_op="Join" to_port="left"/>
<connect from_op="Detect Outlier (Distances)" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="right"/>
<connect from_op="Join" from_port="join" to_port="result 1"/>
<description align="center" color="yellow" colored="false" height="68" resized="true" width="178" x="484" y="282">Turn this operator off to see the difference</description>
</process>
</process>0 -
