Hi there,
I am very new to using FEKO, I am trying to calculate the magnetic coupling between two loops. Starting simple and working my way up......
I created two loops, made them into wire, associated a wire port for each and then only applied a voltage source to one and then simulated for the near field.
Not sure what else I could have done here, the simulation produces a nice image however I am looking for numbers based answers. The plan to is gradually move the loops apart as well as adding sheet material of different conductivity between to form a study.
Any advice would be enormously appreciated!
