I am trying to couple
1. EDEM 2022.2
2, FLuent 2022 R2
3. Visual studio community 2022
the path of each in the attached image faces an error, as shown in the attachment with the EDEM-Fluent-Coupling-V-2-3-1.zip compiler. There is no option for EDEM 2022.2, Fluent 2022 R2 and VS 2022 error shown as attached. Please figure out this issue. Is their new compiler available or old will work?
Hi Mahesh,
You can download the latest version here - https://community.altair.com/community?id=kb_article_view&sysparm_article=KB0116549
This supports fluent 2022 R2 and other 2022 versions.
Regards
Stephen
I don't know how you're getting those errors, I've not seen anything like that before. I tried with both Visual Studio 2019 and 2022 and have no issues with the compiling side of things, which your errors relate to.
As Stephen mentioned, try the latest version of the compiling tool first, but if you're still seeing these errors then I'd maybe try reinstall Visual Studio, making sure you install the C/C++ compiler options.
Cheers,
Richard
Hi Mahesh, You can download the latest version here - https://community.altair.com/community?id=kb_article_view&sysparm_article=KB0116549 This supports fluent 2022 R2 and other 2022 versions. Regards Stephen
thanks of issue resoved
Hi, I don't know how you're getting those errors, I've not seen anything like that before. I tried with both Visual Studio 2019 and 2022 and have no issues with the compiling side of things, which your errors relate to. As Stephen mentioned, try the latest version of the compiling tool first, but if you're still seeing these errors then I'd maybe try reinstall Visual Studio, making sure you install the C/C++ compiler options. Cheers, Richard
Thanks for your kind support. I faced the issue after reading the journal file in Fluent and unable to understand how to fix the issue as attached.
