How do i plot my 240 long position vector as an x,y,z 80 dots 3d figure
Talefjanten
Talefjanten New Altair Community Member
Ill explain: I have a 240 attributes, each pair of 3 contains my x,y,z [-0,8985544 0,6975544 2,48755878], i want to plot these 80 points in rapidminer to produce my "skeleton" in a 3d plot, but i have no idea how even to start!
Best Answer
  • jwpfau
    jwpfau
    Answer ✓
    Here is an example how you could transform the [x y z] string into three different attributes.
    <?xml version="1.0" encoding="UTF-8"?><process version="10.1.002">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="10.1.002" expanded="true" name="Process">
        <process expanded="true">
          <operator activated="true" class="utility:create_exampleset" compatibility="10.1.002" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="34">
            <parameter key="generator_type" value="comma separated text"/>
            <parameter key="number_of_examples" value="100"/>
            <parameter key="use_stepsize" value="false"/>
            <list key="function_descriptions"/>
            <parameter key="add_id_attribute" value="false"/>
            <list key="numeric_series_configuration"/>
            <list key="date_series_configuration"/>
            <list key="date_series_configuration (interval)"/>
            <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
            <parameter key="time_zone" value="SYSTEM"/>
            <parameter key="input_csv_text" value="coordinates&#10;[1 1 3]&#10;[2 2 2]&#10;[3 3 1]"/>
            <parameter key="column_separator" value=";"/>
            <parameter key="parse_all_as_nominal" value="false"/>
            <parameter key="decimal_point_character" value="."/>
            <parameter key="trim_attribute_names" value="true"/>
            <description align="center" color="transparent" colored="false" width="126">Replace With Read Excel</description>
          <operator activated="true" class="replace" compatibility="10.1.002" expanded="true" height="82" name="Replace" width="90" x="246" y="34">
            <parameter key="attribute_filter_type" value="all"/>
            <parameter key="attribute" value=""/>
            <parameter key="value_type" value="nominal"/>
            <parameter key="except_value_type" value="file_path"/>
            <parameter key="block_type" value="single_value"/>
            <parameter key="except_block_type" value="single_value"/>
            <parameter key="replace_what" value="\[|\]"/>
          <operator activated="true" class="split" compatibility="10.1.002" expanded="true" height="82" name="Split" width="90" x="380" y="34">
            <parameter key="split_pattern" value="\s"/>
            <parameter key="split_mode" value="ordered_split"/>
          <connect from_op="Create ExampleSet" from_port="output" to_op="Replace" to_port="example set input"/>
          <connect from_op="Replace" from_port="example set output" to_op="Split" to_port="example set input"/>
          <connect from_op="Split" from_port="example set output" to_port="result 1"/>
        </process>
    </process>
    Afterwards you only have to select the x-axis, y-axis and Value column (z-axis) in the Scatter 3D Plot.
    Greetings,
    Jonas
  • jwpfau
    jwpfau
    Answer ✓
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
        </process>
    </process>
    Greetings,
    Jonas
